Undesired sticky selections
ltomuta
Advisor Advisor
ltomuta
At times Fusion gets into a mode in which everything I click in Browser gets selected (as if CTRL+clicked  or something). When this happens I cannot unselect undesired things and the right click menu that opens seems to belong to the first item selected (setup1 in this case) and not the right clicked item.
Known issue?
ltomuta
Here's a screencast showing the problem. It ends with a crash that may have sent relevant info to Autodesk. https://autode.sk/3wxXaWT
alex_farleyM29AH
I am having this same issue. any idea to the solution?
jeff.pek
Hi Lucian -
I see 3 reports from you today. Do you know which one this was? It looks like the first of the 3 was different from the last 2.
  Jeff
ltomuta
Hi Jeff
This is an old problem I have not seen on my side for a very long time. IIRC this was one of the things I was getting that was [indirectly] linked to Fusion's data parsers not liking my System Locale settings (mainly the fact that "," and "." are swapped around in ro-RO compared to en-US). That used to cause a crash and this was one of the things I was seeing after the crash, until a new restart was done. Then this would go away too.
I do remember being told that the parsing issue was fixed but the release of the fix as never explicitly confirmed.
My recent crashes are a bit of a mystery to me but I'm yet to find time to dig into it. They happened in areas where I also have add-in code running.
