Because I choose a complex design for my project, I made it difficult for myself in the production stage.
The project consists of 9 different "legs" each 50 layers.
Please see attached image.
I can produce most of the layers very easy and fast, but ...... there are lots of layers with a complex form.
In those situations I need to produce double sided, because there is a positive and a negative slope on at least two sides of the layer.
Double sided production is not the problem ......
The centre of the big hole is point zero.
The model has 4 extra holes that go through the spoilboard.
After rotating I put 4 pens in the holes + spoilboard and with this I reach the exact zero point (again the middle of the big hole).
To cut out the layer, I defined a 2D Contour toolpath and thereafter I do the slope with a 3D Contour.
After turning the layer I produce the slope in the other direction.
The problem is that the 2D Countour of the first layer takes away all the material for the second slope. So the second layer run makes no sense, because there is no material left.
I get the idea that this could be a program mistake.
Is there somebody who can help me please?
