Understanding Post Process and zero RPM with multiple toolpaths.
I am a little confused about posting multiple tool paths and separating them by tool paths NOT tool numbers.
Let's say I have 6 tool paths for this part and 3 of these tool paths contain the same endmill. When I process the "setup" it brings in all the tool paths for that setup. I then want to separate them by tool path even though a few still contain the same endmill. Why doesn't the toolpath contain an RPM? The first tool path will contain RPM so I am assuming that Fusion thinks the others will follow the first one but when each toolpath has finished the spindle stops, I load the next tool path and try to start it but again, ZERO RPM. Do I have to post process each tool path individually or is there a way to work around this? Why would Fusion assume the tool path already has the spindle running when each path has been separated?
I kind of understand when you separate each path by the tool numbers because the tool paths are combined at that point into 1 file. I hope this makes sense to someone?
