Undercut radius with which operation
marcus.toepke
marcus.toepke
Hi!
I have a handwheel that I want to mill on a 5-axis machine, which operation would you use to machine the R1 radius in the undercut?
programming2C78B
depends on your orientation...parallel or scallop are my first choices.
Please click "Accept Solution" if what I wrote solved your issue!
marcus.toepke
Parallel works with undercuting? I don't think so!
a.laasW8M6T
Hi
Blend, Flow and Geodesic will all machine undercuts  in 5 axis(and 3 axis with Spherical tools)
Flow is probably the easiest one to start with.
marcus.toepke
I tried it with steep and shallow, it works, but the tool runs all the time through the material^^
I will try your suggestions
marcus.toepke
Ok with Geodetic I was finally able to get it right
Thx!
