Under Cutting for Thread Mill
jgiacchi
jgiacchi
   I am attempting to figure out how to perform an undercut before I perform a thread milling operation so that I can relieve the bottom of the hole and allow full thread engagement of the screw.  The thread is 8-32, so I use a starter drill bit, then a #29 drill, then the attempted undercut operation for a diameter to 0.164 from the depth -0.22 to -.55 from the model top, then a thread mill from 0 to -0.23 depth.
   I am having two points of difficulty:
   While looking at tutorials and troubleshooting i had to utilize a negative stock to leave in order to have it create the profile and I am not sure why?  Do I need to offset the size of the undercut in the model and then calculate the difference with the negative stock to leave?  That just seems counter intuitive and I am not sure that I am understanding the process flow correctly.
   I can get a toolpath to successfully generate that will perform the undercut, but when the tool retracts it does not return to the center of the hole and will have a collision with the stock.  How to I adjust the retraction so that it avoids the walls?
   I tried various different toolpaths such as 2d Contour, 2d Adaptive, 3d Contour and 3d Adaptive, but 3d Adaptive was the closest I could get to what I was attempting to accomplish.
Any assistance anyone could provide would be much appreciated.  I am also sure I have probably left something off, so let me know what other details you might need,
Jim
Accepted solutions (3)
Try Bore, given the size of tool and hole, you may want to take more conservative approach on chip load, I adjusted tool parameters to suggest potential solution, "return to center" is key to clearing the wall.
Richard.stubley
Hi @jgiacchi,
I tend to use circular with Lead to centre ticked for times like this.
Richard Stubley
Product Manager - Fusion Mechanical Design
Richard.stubley
@Anonymous sorry, just seen you beat me to this one 🙂
Richard Stubley
jgiacchi
Thank you so much!  This is almost perfect.
As for chipload, I used HSM Advisor to figure it out.  As I was playing with so many things I may not have put the correct speeds and feeds in when I posted the file, but I was planning on using a .125 Diameter Cutter with a .25 Length of Cut.  The Width of Cut will be 0.014 and the feed will be 2.66 IPM.  That should be pretty gentle on the tool at 0.00026 in, I am almost worried I may get some rubbing, but we will see how it works.  If you have any suggestions though I am all ears.
One thing I have noticed is Fusion likes to fully retract the tool in between passes if you attempt to do multiple passes.  Is there a way to change that so it stays at depth and does each pass?  I've noticed a similar behavior for the threadmill as well and it seems to waste a lot of time with movements up and down.  My machine is a Tormach 1100 so it's rapids are rather anemic.  If possible I'd like it to not fully retract, even a partial retract if it needs to clear chips would save a lot of time.
Thanks again!
Jim
There is no option to keep the tool down in thread milling but you can edit resulting code, although with such a small diameter hole you may be better off retracting after each pass to flush the chips out.
