I'm new at Fusion and I was wondering if you could help me with issue I'm having.
My issue is with the toolpath setting, and the order in which they're cut. Fusion use to cut all the details with in the design first, and then cut the profile path last. Now it's cutting the profile path first, and then all the details within the design last. This presents a problem because I'm cutting with a plasma cutter CNC, and on smaller pieces cutting the profile first causes the part to fall into the table water and there is no part present to cut the details of the design. I've been trying to resolve this issue for about a week now, and I can't figure out where I'm going wrong. Even the designs I made in the past that cut out perfect are now cutting the profile first and then the details second. How do I control which toolpath is cut first and so on? Thank you for your time. Alan
