Unable to chamfer completely
MetalRipper_
MetalRipper_
Hi folks,
There is this bore that I need to chamfer. But somehow, fusion doesn't do complete chamfer on this bore. I'm not able to find what's stopping it from doing. Any help would be appreciated.
Thanks.
Gokul Kannan
Making Parts at MetalRipper using Fusion 360
Youtube.com/@metalripper-
CNCexpert.com/gokul-kannan
a.laasW8M6T
Hi
It seems to be to do with the surface triangulation tolerance
If you right click on the toolpath and go to compare and edit then reset to system default it works
Then you will want to save as user default
Andrew Laas
Senior Machinist, Scott Automation
