Message 1 of 13
05:21 PM
Got a problem when using the UCCNC post processor in Fusion360..... when I'm setting "G53" instead of "cleareance height" it gives me a code line at the beginning of the gcode "G53 G0 Z0".
How can I change that to G53 G0 Z20 for example? I was searching through the code of the postprocessor but can't find it. My problem is that scratching over the material when moving from zero to the starting point of the very first drilling point.
If someone could help me out, where to find it, or even better, maybe change it for me with description where in the postprocessor code I could find the addition/change, I would appreciate a lot.
Thanks a lot in advance & greetings
