Trouble with pocket selection/path
filgate.j
filgate.j
Ive been using fusion for a couple years but havent' quite got a handle on this pocket machining thing. I have what i think is called an open pocket, where i want to machine away material without leaving a edge. The best solution i have is to sketch an oversized pocket. Is there a setting somewhere to choose to remove the edge material? here's the part and the typical tool path i get.
seth.madore
Can you share your file?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
filgate.j
File attached to this post
seth.madore
All you need to do (in most cases) is just select the face:
 Result:
Seth Madore
filgate.j
yup. wow. that works. Not sure where i picked up the habit of adding a sketch for a pocket selection. Bad habit i guess. thanks
