Trouble cutting simple shapes after updating fusion
jta49
Message 1 of 10
jta49
I have a simple 48in circle I am trying to cut out, however I am getting many error messages. I have cut out simple shapes like this thousands of times over the past years, and ever since I updated fusion it is no longer working. Any Idea what is going on  here? See attached file.
Replies (9)
Message 2 of 10
seth.madore
I'm not seeing any error in the toolpath:
Are you seeing this in your Fusion, or is this when you post process the file?ā€ƒ
Seth Madore
Message 3 of 10
jta49
Hmm weird, In my fusion it is giving me multiple "shaft collides with stock errors". Also, when I post process over to my machine I get a different error saying "Radius at start is differrent from radius at end".
Message 4 of 10
jta49
Hmm weird, In my fusion it is giving me multiple "shaft collides with stock errors". Also, when I post process over to my machine I get a different error saying "Radius at start is different from radius at end".
Message 5 of 10
seth.madore
Oh, you didn't mention that this issue was showing up in Simulation. The length of flute is less than the thickness of your part.
Seth Madore
Message 6 of 10
seth.madore
What post processor are you using?
Seth Madore
Message 7 of 10
jta49
I have a Hendrick HLD-510 machine, with OSAI controller.
Changing the flute length of the bit solved the simulation error!
Once loaded into my machine though, I am still receiving the radius error.
Attached is my post.
Message 8 of 10
jta49
Here is a picture of the error I am receiving
Message 9 of 10
seth.madore
What happens if you tick this box?
ā€ƒ
ā€ƒ
Seth Madore
Message 10 of 10
jta49
That solved it! Thankyou!
