trouble creating usable simulations
maker9876
maker9876
Whenever I do a simulation it's always a struggle to see what's going on.
Initially thought it was the software, but it's been like this for so long now am inclined to think I just don't know what the hell I'm doing.
In the below image have just "run" an adaptive clear (the holes) and a slot (it's 1mm deep and you can't see it at all, just the toolpath) in the underside of a 13mm sheet of whatever. If simulations are supposed to help with error checking etc then this one is definitely a fail because have to imagine what is going on! Undoubtedly this is at least in part due to the fact that we are "underneath" and the sun is on the other side. But really?!!! How does one make useable simulations?
johnswetz1982
You are looking from the "Bottom" of the view cube so your looking at the shadowed side of the part that is in darkness. You can try reorienting your view cube so that your bottom is is top.
Alternatively you can mess with the lighting settings and turn object shadow off or last ditch rotate your part so that your bottom is now your top.
maker9876
Great trick! Can live with that.
Thanks a lot!
