Trace: Random plunging moves
FrodoLoggins
Advisor Advisor
FrodoLoggins
This is the contour I selected:
The toolpath is fine on one side and does exactly what it should on both sides, but right here the tool on just the right side randomly plunges down here:
And gouges my part:
Toolpath settings:
Screenshot 2025-03-03 at 2.27.00 PM.pngScreenshot 2025-03-03 at 2.27.18 PM.pngScreenshot 2025-03-03 at 2.27.22 PM.pngScreenshot 2025-03-03 at 2.27.28 PM.pngScreenshot 2025-03-03 at 2.27.32 PM.png
Same thing if I drive it off a sketch:
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
seth.madore
Could you send me the part?
Seth Madore
seth.madore
I will add; the Trace toolpath is not really the best choice for what you're doing, it will likely always overcut at some point, as it's not model aware. You could work around this by sketching out the correct path for it to follow, but no guarantees..
Seth Madore
FrodoLoggins
It also makes these little non lead in lead ins and I don't believe it should:
Yeah I usually need to drive these off sketches when I do this. What toolpath would you recommend instead?
seth.madore
Project and Corner (the latter is a MFG Extension toolpath)
Seth Madore
seth.madore
As a temporary workaround, you could limit the Max angle to 89.999 degrees, you'll get this:
Effectively the same, really
Seth Madore
seth.madore
I've opened CAM-61048 to investigate
Seth Madore
