tool size warning fault
EpicSam
EpicSam
i'm trying to create a finishing pass on the radial side of some fins.  for the roughing i have used a 1/4 flat end mill, the slot size is 3/8.  this is working fine.
When i go to add another slot operation with the same 1/4" end mill, is shows a warning that the contour is too small or the tool is too big.  again, the tool is 1/4 and the slot is 3/8. not sure why this error is coming up and how to overcome it. thanks.
programming2C78B
no need for Slot toolpath here, just use 2D contour
Please click "Accept Solution" if what I wrote solved your issue!
