Tool Plunges to Z0 at start of job
At the start of each job my CNC plunges to the set bottom hieght, retracts to clearance height then moves into the correct starting position and runs the job fine. This only started happening after I re-installed Fusion 360 on my computer. Is there some setting in Fusion that is causing this or a particular line of code?
I have tried comparing earlier codes that were fine but cannot see where the problem would be.
I have also tried running earlier codes (before reinstallation) through my toolpath program again and even these ones now incorporate the same starting plunge problem.
I have a multicam CNC using an old Toolpath software to load the the code onto the machine.
Does anyone have a solution to this problem? Is it a Fusion or Toolpath issue?
