Tool Path will not go outside the perimeter of model yes stock is larger.
Inspections_JCH
Inspections_JCH
This is my first time creating a tool path with Fusion 360, and I am sure i saw this addressed on YouTube but I cannot find it now. The I have a model that is very nearly a circle that is 10 inch diameter. The stock is 12"x12" so there is plenty of room. for the tool bit. What setting in the Setup should I be looking for that is preventing the tool path from doing the entire exterior of the part?
@Inspections_JCH
Most likely to be your selection under the Geometry tab or you may have set a "Stock Contour"  that is restricting your toolpath.
Best thing to do is upload the file instead of images, no one can check your settings from images.
Go to:-
File > Export > Select f3d format > Save to a location on your computer > Then attach the file to your next reply.
Inspections_JCH
Attached is the file.
@Inspections_JCH
Try it with a 2D Contour instead, works better. File attached.
Inspections_JCH
Thank. I found the issue for this setup in the Geometry and was able to get a tool path that was complete. I will also try the 2D contour as suggested by @Anonymous and see which I may prefer.
Inspections_JCH
I appreciate the help with my first ever tool path.
