- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- パーマリンクを表示
- 印刷
- 報告
I've been battling this one for a while and have not found a solution yet.
I have a part in a 5 axis trunnion (A is tilt and C is rotary). I need to drill a hole in the A-90. C0. orientation but Fusion posts A90. C180. In many cases this is 6-in-one half-dozen-in-another but because my part doesn't clear the max swing diameter of the C axis I can't spin the part around to C180.
It seams to me that the "Flip Axis" when setting up tool orientation would allow me to switch between A-90. C0. and A90. C180. but this isn't the case. Regardless of how I set up the tool orientation I get the same posted code. I have tried several post processors and have even tried using the machine library/configuration with no luck. I should note that the "Flip Axis" works as expected for the Z axis, but flipping X or Y seems to do nothing.
Has anyone else ran into this and found a solution? At the very least can someone educate me on what the "Flip Axis" option does?
Unfortunately I'm working on a proprietary design so no f3d file but please let me know if you need more detail. Thanks in advance for any input.
解決済! 解決策の投稿を見る。
