Tool Library won't load
Walbergprecision
Walbergprecision
I go to select a tool for a toolpath and it starts to load like normal but then goes blank. It won't load even if I leave it alone for awhile. I have tried to shut down and reload and different jobs and same thing happens to all. Anyone else having this issue or know of a fix?
seth.madore
When Tool Library issues like this pop up, it's almost always down to graphic card and drivers. Are these up to date?
Seth Madore
Tianq
Hi @Walbergprecision ,
Does the Tool Library not load when you open the Tool Library dialog? Have you tried restarting Fusion 360 to see if that helps?
The issue could be caused by a slow internet connection.
To help diagnose the problem further, it would be helpful if you could share the log files.
Dave (Qing) Tian
Walbergprecision
Drivers are up to date.
Walbergprecision
Speed Test of internet is good. what do you want for log files? You mean like the actual file?
Tianq
Thanks for checking.
You may check out this post for sharing the log files - https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-find-and-sh...
Dave (Qing) Tian
