Tool Library requests
HughesTooling
Consultant Consultant
HughesTooling
Is there a way to make copies of tools, I need to set up several boring bars that are basically the same just different diameters and different relief angles. It would be a lot quicker to set them up if I could make 6 copies then make one or two adjustments instead of having to start from scratch each time.
While setting up my lathe library I thought I could use the Sample Turning Tools library to save some time but there doesn't seem to be a way to copy and paste libraries between Samples and cloud for example.
The edit mill tool needs updating now there are lathe tools in the library.
Mark
Mark Hughes
Owner, Hughes Tooling
jeff.pek
Hi there -
You can copy tools from one library to another by dragging it from the list view on top of a library node in the list on the left-hand side.
You can copy to any writable library, including the Cloud libraries.
I don't think there's a way to just copy/paste a given tool within a given library.
That would be a nice request on IdeaStation.
Good point about the Edit Tool button caption. Thanks for pointing that out.
Jeff
skrubol
IIRC, the round about way to copy a tool is to edit the tool you want to copy, close it, then create a new tool where you want it and it will open up with the last tool's settings.
Lonnie.Cady
There should be an easy way to duplicate a tool.  In HSMWorks it is very simple ctrl+d
Hopefully something like that will get added.
HughesTooling
I was going to suggest an easy way to make copies is to use the tool you want a copy of so it's in a document library then copy it back to the cloud library. The libraries don't seem to mind if you have several identical tools.
Only problem was the first time I tried it out I copied a boring bar back to my cloud library twice and when I went back to the cloud library all I had were the 2 copies and all my other tools had been deleted for some reason!. Luckily I had the deleted tools in other documents and just copied them back so I don't know what went wrong coping the boring bars.
Mark.
Mark Hughes
peter.pretsch
Hi Mark,
Sorry for the late reply.
The problem with drag and dropping tools to a not yet initialized/activated tool library (CAM-2363) has been fixed and should be coming in an update soon.
Your other issue with the layout of the tool library manager being broken has received CAM-2395, but it should really only be a problem until you resize the window.
Kind regards,
Peter
Peter V. Pretsch
SW Development Manager
coolantslinger
I will second the motion to be ale to copy a tool within the same library. Would save some key strokes on entering repetitive information.
Coolant Slinger
