Tool library: New tool: Cutting data tab/ Speed
jmorphet
jmorphet
  1. Manufacturers data gives me a SFM of 200-2000. My mill’s maximum RPM is 5100. For a 1/4 tool, the 5100 RPM constrains the maximum SFM to 333 SFM. So I have to pick between a SFM between 200 – 333. Any guidance on what to pick and why?
  2. Any reason to have the ramp spindle speed different from the spindle speed?
Laurens-3DTechDraw
  1. Probably best to ask your tool vendor this. They most probably can explain this a lot better than we can
  2. Yes. Surface speed advice changes with the width of cut(WOC) you are using. And ramping usually means full WOC, thus needing a lower surface speed. But this is mainly an issue for harder materials.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
Found out the hard way is the best way to win.
