Tool Height
Tool Height
Tool Height
In the past I have used the center of Ball for toolheight setup, but I am not able to find this setting in Fusion 360
Steinwerks
Currently Fusion doesn't support anything other than tool tip for offset, at least as far as I know.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
jeff.pek
Can you show me a picture of that? Not quite clear what you mean by "use the center of the ball".
  Jeff
Steinwerks
@jeff.pek
This is center of radius tool offset which I believe is most useful for using a 3-/multi-axis radius compensation where the machine is capable of it which is used commonly in 3D mold work where the radius of a ball mill is not exact. The toolpath is programmed from the center of the tool nose radius:
Neal Stein
Find me on:
jeff.pek
OK -- and how did you specify that offset? This isn't a form tool, is it?
  Jeff
Steinwerks
This is just an example to show where the tool offset would be in this situation, a quick mock-up made up in SW.
Edit: ah, yes in HSMWorks I believe it can be set manually but no such functionality exists in Fusion.
Neal Stein
Find me on:
