The new FLAT toolpath is not avoiding selected touch surfaces
stuart.higginsA877K
Message 1 of 9
stuart.higginsA877K
Hi everyone,
I have just seen the promo for the new FLAT toolpath in fusion 360. It is the perfect toolpath for a part I'm about machine that's if i can get it to work.
Basically the surfaces I've selected to avoid are actually capheads so they need to be avoided when machining. I have proven this works when using the horizontal toolpath but the problem is this makes the tool plunge in to the material when it jumps to its next position - which is why i would to get the FLAT toolpath to work.
Can someone take a look and explain what I've done wrong... I've attached the file. Please reference the Horizontal toolpath in setup 1 that does avoid the surfaces and the FLAT toolpath in setup 2 has the same surfaces selected but does not avoid the area
Replies (8)
Message 2 of 9
seth.madore
Something more like this?
Seth Madore
Message 3 of 9
stuart.higginsA877K
Hi @seth.madore  yes that's exactly what I'm trying to achieve. What was I doing wrong?
Message 4 of 9
seth.madore
I extruded those patches into Bodies and then included it in the toolpath:
Seth Madore
Message 5 of 9
stuart.higginsA877K
I'm struggling to replicate that..  I've made the surfaces to bodies and turned machining boundary to none as you have it and now i have a toolpath just machining the 5 bodies
Message 6 of 9
stuart.higginsA877K
I've got it now. Seems i had my heights incorrect. Thank you.
Great new toolpath 😃
Message 7 of 9
seth.madore
I should add, that what I(we) did for a solution is really just a workaround. We'll get this logged and worked on in due order
Seth Madore
Message 8 of 9
alarkins66
Community Visitor
Community Visitor
I also saw the YouTube video about the flat machining strategy.  I don't have that option under my 3d tool path selection tab.  What do I need to do so i do have access to this?
Message 9 of 9
mattdlr89
If you have updated to the latest version which should happen automatically then you shouldn't have to do anything else. On mine it is the fourth option down...
