Tap type
Tap type
m_lamarca
Tap type
m_lamarca
Is there a way in the tool library to set up different style taps, such as modified bottoming or plug or taper, so that the tool always knows to go a certain number of leads into the part, to get full thread?
For example, using an M10x1.5 mod bott tap, to get 10mm minimum full thread, the tool has to go 14.5mm deep. With a plug tap, that’s 17.5mm deep.
programming2C78B
no, sorry. I've asked for this before - it could be the same as Drill tip length.
Best you can do now is enter that offset value in the tool description or comment field.
Please click "Accept Solution" if what I wrote solved your issue!
m_lamarca
Man, that sucks. I wish they would steal that module (and many others) out of FeatureCam, and implement it in Fusion360. I understand they are trying to hit a price point, but it’s painful.
