Tangential Extension - Not working like expected
jeph00
jeph00
Good evening everyone.
In the attached part, I have 2 finishing passes programmed. In both, I want to extend the pass out past the back/front limits so the insert doesn't cut the radius on the outside edges. I tried adding a tangential extension of .1 but that doesn't work on both, the toolpath isn't like its supposed to be. Can't figure out why. Any ideas?
Fabbunny69
Hi @jeph00
I removed the tangential extension as this will follow the model profile(ie the radius) and added a lead out at zero degrees.
I think this is what you are after.
jeph00
Yes, that is exactly what I am trying to do. Didn't think of that simple solution. Thank you sir @Fabbunny69
Fabbunny69
No worries mate, glad I could help.
akash.kamoolkar
@jeph00 FYI what you were doing was also correct and should have worked. I've created a ticket to look into it.
Akash Kamoolkar
Akash Kamoolkar
Software Development Manager
akash.kamoolkar
@jeph00
This issue has been fixed in the update that just went out.
Akash Kamoolkar
jeph00
That's perfect. thanks for the feedback.
