Swarf operation error: operation not compatible with current setup
epm
Message 1 of 9
epm
hi
i have a 5-axis machine, and last week i did a project using the swarf operation. today when i try to edit this operation or create a new on, i get an error dialog box:
"The chosen operation is not compatible with the current setup"  [OK]
i double checked my configs, no changes, not sure where to get more information to troubleshoot this issue.
regards
eric
Replies (8)
Message 2 of 9
lee_sanders
Hi @epm
Is it possible for you to share the project or an example project to help understand your issue?
Lee Sanders
Technical Consultant
Message 3 of 9
epm
hi
no problem, its all in the cloud, what do i need to do??
eric
Message 4 of 9
epm
is this it
https://a360.co/2TYIX4h
Message 5 of 9
lee_sanders
hi @epm
Have you selected the right machine in the setup?
I tried it with a genric 5 axis machine and there doesn't seem to be any issues
Lee Sanders
Message 6 of 9
epm
hi
it should be since it worked before today ...
i exported the machine definition, attached (i added the .xml extension)
eric
Message 7 of 9
epm
i just tried the generic and it seemed to work...
does the post processor have any effect at this stage??
eric
Message 8 of 9
epm
when i first started using fusion, i just did add a new machine and filled in the details ...
the generic one seems to have more config for the a & c axis ... i don't know how to enable this config for the one i did for the felder??
eric
Message 9 of 9
epm
hi
i think i figured it out,  when i created my machine i did not load a template and just the default which seems to be for a 3-axis machine ... i "loaded" the generic template and now i get the other 2-axis configurations
it was the fact it did seemed to work last week that confused me
i will use the 5-axis template and go from ther e
thanks for your help
eric
