Evening
I am trying to set up a chamfer bit to shape a part.
I have successfully milled slopes before (I've attached the file - slope test example). And have tried applying the same rules to this new project, with little success.
I am hoping that someone will be able to help.
The main issues I am having are:
it is starting at the bottom, I would like multiple passes from the top down - i've tried clearing material first, but haven't quite got that working yet either.
several of the passes are just wasted time as the bit travels through the air.
it is not milling the entire shape
Any suggestions greatly appreciated, I'm sure Fusion can do it, and don't fancy having to resort to modelling each pass individually!
Thanks in advance
Rebecca
