Strategy problem
Strategy problem
marco_bazzali
Strategy problem
marco_bazzali
I have a problem with my strategy, when I put the reference point in the middle of the model; the strategy generated with a spiral like I want.
But when I put the reference point at the middle of the hole that I want to work, the strategy generated is different, without spiral but with circle connected... I really need that my strategy goes with a spiral path...
How I can fix that?
engineguy
@marco_bazzali
You are best using the middle of the model for the WCS, it works fine there, or any corner as well 🙂
Why would you need to use the center of that hole for the WCS ??
Stay Safe
Regards
Rob
marco_bazzali
Hi Rob,
Thanks for your reply,
I like to use the center of the hole as WCS for ease, by calculation of quote but at the end it's no difference.
But I don't understand why the WCS will affect my strategy, in another model with different shape I don't have this kind of problem, the strategy is the same with different WCS.
What can be that the same exactly strategy would be different without same WCS?
Take care
Marco
engineguy
@marco_bazzali
Hi Marco
I agree it is strange and I don`t really have an answer as to why it does the circles but when I selected the center point of your sketch it worked OK so just select the center point of the sketch and it should be the "workaround" needed if that will do for you, obviously a "bug" of some kind 🙂 🙂
Stay Safe
Regards
Rob
