Okay, I'm trying to do some Mission Style inlay, I've created a fusion file with with the spline tool, exported it out as a DXF file. After that, I opened it in Illustrator, and re-saved it as an SVG file. After I insert this SVG file onto the top of a piece of stock, I'm unable to select certain parts of it for the negative extrusion I want to do. If I use the DXF file, I can get the extrusion I want, but resizing it is a real problem. I can resize the SVG file just fine, but not all faces are available for selection for the negative extrusion.
