The whole idea is you model what you want to cut, you generally do not want to cut into the model.
If you setup like this with stock above the part then set the Origin to Stock Point and pick the corner of the stock box there will 0.025 to take off. You already set the stock top offset to 0.025 `but your origin was model top not stock top, so nothing to remove.
See attached file. I set the facing op to leave 0.005 so the parallel will take the last 0.005.
Mark
Mark Hughes
Owner, Hughes Tooling
