STL MACHINING FAIL MARCH 2021
arlimbad222
Message 1 of 14
arlimbad222
After march 2021 update fusion 360 create mess with stl machining in parallel tool path i just copy and pastE toolpath of my old design to new one but fusion 360 not recognize my stl it just create flat tool path i don't know why i attache some screencast please help .
https://knowledge.autodesk.com/community/screencast/0efdf2f3-ab56-4d43-89a8-2d473fc69b6b
Replies (13)
Message 2 of 14
Marco.Takx
Hi @arlimbad222,
Can you please share your file?
Without seeing it, it is hard to help you with your problem or investigate for Autodesk what is going wrong.
Within Fusion 360, choose File > Export and save it on your desktop.
After that upload it to this topic so that one of us can take a look at it.
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
Message 3 of 14
HughesTooling
Have you got the STL selected as the model in the setup?
Mark
Mark Hughes
Owner, Hughes Tooling
Message 4 of 14
arlimbad222
hello sir first thanks for response
Everything working perfectly before update last night I update fusion 360 and my design create a mess I don't know why I attach my design file please give me solution my customers are waiting for product . And I am stuck here.
Please watch video I just generate a toolpath nothing changes just hit that generate button and everything gone .
I completely remove fusion 360 2 times and install again with default settings but nothing happens.
https://autode.sk/3be1q62
Message 5 of 14
arlimbad222
I try almost each and everything with stock and model selection but I am fail & almost give a 12 hours to solve this problem but I am fail and then I posted here
Message 6 of 14
arlimbad222
HI@Macro.Takx
Message 7 of 14
HughesTooling
@seth.madore  Any ideas on this?
Mark
Mark Hughes
Message 8 of 14
seth.madore
We are starting to track this bug as more issues are popping up. No news at this time, I'll circle back when I have more to offer
-EDIT- I've opened up CAM-28011 to track this issue
Seth Madore
Message 9 of 14
arlimbad222
Hi @seth.madore
Thank you for response please give me update whenever this bug fixed.
have a nice day all .
Message 10 of 14
zero_divide
First time trying to machine an STL in Fusion.
Having an issue with the toolpath generation AWAY from the model.... See the toolpath in the lower-left corner....
Tried pretty much anything but it seems to think my model is ways off.  This does not happen when machining parts designed in Fusion.
Message 11 of 14
Richard.stubley
@zero_divide,
As Seth has said, we are investing the issue and working on a fix.
The issue seems to be when you import and move the mesh. The toolpaths are going to the import location. Not the new location.
So there are 2 work around you can try.
1 import the mesh and don't move it.
2 if you have to move it then try this.
You have your main document lets call this "main doc" you want the mesh in here to machine.
Now make a new document, insert the mesh into here and DO NOT MOVE IT, just import. Save this as "Mesh1"
Now insert as a derive "Mesh1" into "Main doc"
You should now be able to move the mesh around to your hearts content and still reference it correctly in the MFG environment.
We will of course try to get a fix out but this may at least keep you working
Richard Stubley
Product Manager - Fusion Mechanical Design
Message 12 of 14
HughesTooling
Here's a fairly quick\easy workaround using the info from @Richard.stubley  Just export the mesh in it's moved position then delete from the document. Then just reimport the mesh that will now be in the moved position.
Screencast below using model @arlimbad222  attached.
Mark
Mark Hughes
Message 13 of 14
arlimbad222
First thing first sorry for late response .
I find this solution last night and finally start machining this coin so I am very tired last night.I do the same thing as shown in video and it's working for me . But I think it's temporary solution.
Thanks all for help and give a time for this issue.
I attached some beautiful picture of product .
Message 14 of 14
shane.waid
Very nice!
