Steep and shallow "toolpath Has No Sections"
Collin_Korver
Message 1 of 20
Collin_Korver
within the last update about half my steep and shallow toolpaths now give the error "toolpath has no sections". It displays the toolpath, the points are there, but it does not simulate the tool nore post the operation. It even messed up protected operations. This is a problem because this job needs to run this weekend!
https://a360.co/3i6EB5y
Replies (19)
Message 2 of 20
Collin_Korver
Screencast
f54a4f3f-b93b-4e1c-923a-b7419ed7e0a5,640,650
Message 3 of 20
Collin_Korver
<iframe width="640" height="650" src="https://screencast.autodesk.com/Embed/Timeline/f54a4f3f-b93b-4e1c-923a-b7419ed7e0a5" frameborder="0" allowfullscreen webkitallowfullscreen></iframe>
Message 4 of 20
Collin_Korver
The Bug seems to be spreading. I now have a contour toolpath that no longer works.
Not sure why I struggle so much with uploading screencastings. So here is the an alleged screencast link of my contour struggles https://autode.sk/2CF5w8a
Message 5 of 20
Collin_Korver
My toolpaths are falling like peasants during the black plague to the "toolpath has no sections" bug. Now have 3 swarf toolpath failed
Message 6 of 20
Collin_Korver
Apon application restart, fusion 360 has stopped generating tool paths all together. TOD 10:23.
Message 7 of 20
Collin_Korver
The bug seems to be originating intermittently inside the Trim Toolpath modification causing cascading failure of all subsequent operations.
I now have an example where I can force and fix the toolpath has no sections error by deleting a modify toolpath.
Bug Isolation "toolpath Has no sections" | Fusion 360 | Autodesk Knowledge Network
Message 8 of 20
LeeVerage
We are now experiencing the same issue with toolpath trimming using steep and shallow, parallel, 3d contour and Flow.
Any fix for this Autodesk?
Message 9 of 20
Collin_Korver
I have requested 3 "need an answers" and I have not received anything. The work arounds I have been using involve patching off the areas that I dont want. other than that if that operation decides it doesnt like toolpath trimming there is nothing to be done except not trim it.
Message 10 of 20
Collin_Korver
@LeeVerage Were the operations of your "modify toolpath" that were causing failure inside a folder?
Message 11 of 20
oscar-cadcampilot
Same here.
The Toolpath Trimming seems to be breaking not only the toopaths that was modified, but also any toolpaths that follow.
Oscar Romero
Owner | Product Specialist
@ cadcampilot
Message 12 of 20
oscar-cadcampilot
@Collin_Korver Consider renaming the thread to something like "Trim Toolpath is broken" as it doesn't seem to be limited to just the Steep and Shallow toolpath.
Oscar Romero
@ cadcampilot
Message 13 of 20
LeeVerage
Agreed Oscar.
I've done some testing and Trim toolpath appears to be broken when either the original or trimmed toolpaths are placed with in folders.
Message 14 of 20
oscar-cadcampilot
@LeeVerage for me it's broken regardless if it's in the original folder or sub-folders.
Oscar Romero
@ cadcampilot
Message 15 of 20
seth.madore
Yes, the issue is with Trim and Folders. As mentioned earlier in the thread, there is a solution being worked on. Keep a close eye on the next hotfix or two, we may see a solution come out.
Seth Madore
Message 16 of 20
Collin_Korver
It actually did have something to do with the folders??
Message 17 of 20
seth.madore
Yep
Seth Madore
Message 18 of 20
seth.madore
An update went out last night that should address this issue. Let us know if it's still present!
Seth Madore
Message 19 of 20
oscar-cadcampilot
@seth.madore
Looks like the issue was fixed in the latest update.
Thanks for staying on top of it!
Oscar Romero
@ cadcampilot
Message 20 of 20
LeeVerage
Hey @oscar-cadcampilot
Yes, agreed.  With the few tests I did after the last F360 update, it appears to be working better now as expected.
Thanks Autodesk F360.
