Steady X- Axis while milling on lathe in Z axis
Michal.gutek.woroniecki
Hi Guys,
I'm trying to mill cylindrical shape on Hass ST -10 with milli/drill option in Z- axis, problem is that X axis moves along with C - axis (main spindle) and it creates a small steps, when it can be done same way as conventional Turing where knife stands steady and main spindle turns. Many similar parts are needed so I need to find a way to make setup from fusion not by writing it. Maybe there is a chance to make easy setup like this. Zrzut ekranu 2020-09-3 o 13.58.58.png
Ketherton21
change your lead in and lead outs or disable them and ramp it.
watch your stepdown if you use ramp, a bunch of the tools here reset to some crazy number (from the sample section)
Precise HIT !!!
Works perfect, If someone has same situation look below for setup with 2mm overlap so main spindle makes more than full rotation for smooth finish. Thanks for Quick answer
Ketherton21
