Standardized Templates using Containers
TronIndustriesInc
Message 1 of 9
TronIndustriesInc
Hi Everyone!
I am relatively new with Fusion 360 and I just watched a video from an Autodesk University presentation called Streamlining CAM Workflows by Rob Lockwood. The video is posted on NYC CNC's website and I really like the way Rob has structured his workflow for efficiency in programming. Now the video shows all the great benefits on what this can do, but what I do not understand is how the actual structure of his template was developed. If you go to the video linked in this form post and stop it at 19:53 you will see he is giving a breakdown of how each component is used. I have also attached a screenshot. Does anyone know of a tutorial video on how to properly set this up? I have been trying to build something like this myself from this video, but I am not getting the same result as Rob.
I appreciate all the help in advance!
Dyson
Replies (8)
Message 2 of 9
Rob_Lockwood
Well, there's really only one person with a decent shot at giving an accurate answer..
The assembly structure is just built by making new, empty components, and then linking those into places that allow components as CAM selections. The structure itself is something I made up, it works for me, but should be considered moderately flexible, I think it's something that will change considerably given different processes.
Rob Lockwood
Maker of all the things.
| Oculus | | Locked Tool | | Instagram |
Message 3 of 9
CuttingEdgeManufacturing
i'd like to watch that video myself.. care to post the link? i think you forgot it or i completely skipped over it.
Message 4 of 9
TronIndustriesInc
Here is the link: https://www.nyccnc.com/growing-into-a-5-axis/
It is the video on the far right in the row of three.
Message 5 of 9
TronIndustriesInc
Hi Rob,
Glad to have the creators advise! The structure you have will work for my application, but I think I just need to get more familiar with some of the option in Fusion like using parameters for stock size, the synchronize active set up and assemblies in general.
Thanks!
Dyson
Message 6 of 9
Rob_Lockwood
the fusion files used in the class should be available for download somehow through the AU portal, you may have good success reverse engineering those!
Rob Lockwood
Message 7 of 9
TronIndustriesInc
Hi Rob,
Just found the files on AU portal. I didn't even know I had access to all those resources!
Thank you very much again for all the help!
Message 8 of 9
Great resource!!
Thanks!
Message 9 of 9
zpawlakXYRDT
Observer
Observer
Can someone share the link to those files?
