Stability Issues...
Stability Issues...
LibertyMachine
Mentor Mentor
Message 1 of 166
Stability Issues...
LibertyMachine
Anyone else having serious stability issues? Prior to a few weeks ago, I could count on one hand the number of Fusion crashes I've experienced, and those I could always point to something stupid I was doing that lead to it. Now, I seem to be crashing at the least little thing. Go to Model, change a small feature, go back to CAM and click on the Setup. Freeze and Crash.
Open up an Operation, zoom in to select the proper chain. Crash.
Select a bunch of operations and CTRL+G. Crash.
Please tell me I'm not alone in this. You guys all know I love the software, so this isn't a rant, just more a plea out of desperation......
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Replies (165)
Message 2 of 166
HughesTooling
I've not noticed more crashes, the post with the arc splitting up where I figured out it was because the first sketch was not fully constrained for example. You said you got a crash just selecting the setup after modifying the sketch, I didn't have that problem. It would crash if I just tried a regen, that has been a problem for a long time but I could edit the op and reselect the contour no problem.
I think the update 2 weeks ago made Fusion unstable for some, when everyone was complaining I built a mould tool without any trouble and in the last 2 weeks worked through to machining and it's all gone quite well. The tool has external linked\imported step files that drive the cavities and the impression blocks have some complicated links back to the step files and it's all gone better than I expected.
Here's a screen grab of the model.
And maching for the cavity and core.
One bug I have noticed and reported is ops and setups disappear if you go to the model space then back to CAM. I haven't figured out a repeatable pattern though.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 3 of 166
LibertyMachine
Interesting. What you have is definitely more complex that what I have. I SO wish I was having this issue on any of my normal parts. The 4 jobs I've got issues with (so far) are all buried in NDA so it limits what I can share. In specific instances, I have stripped out a lot of stuff and sent it off to AutoDesk for evaluation. They were able to reproduce the crash but had no clue what was causing it...
EDIT: And yes, after every crash I submit a Crash Report, if it gives me the option. Sometimes it just stops responding and I have to force close and I don't get the option to submit
Seth Madore
Message 4 of 166
HughesTooling
Are the designs you're having trouble with new, started in the last couple of weeks or something you started a while ago. Some people seem to be having trouble with older projects.
Mark
Mark Hughes
Message 5 of 166
LibertyMachine
Both of the crashing files were created and modeled a week or so before the update a few weeks back. I did not start applying CAM data to them until the day of the update. It's been a struggle since then. I never thought of dumping everything and starting from scratch. Kinda too far into that to consider that option 😞
Seth Madore
Message 6 of 166
CNCBits
New here so take comments with a grain of salt. I have just started using F360 and found on an AMD desktop computer it crashes regularly but on my core i7 laptop it is far more stable
Just my 2c
Nick
Message 7 of 166
LibertyMachine
I wish it was simply a hardware issue. I'd go out right now and buy the best desktop (or laptop) I could find. My computer is running an i7, 32gb ram, 2gb nvidia. Yeah.....
I mean, it "might" be a computer issue. I did build this machine, but it's running all legit software, no random programs running in the background, just exists for me to run my shop.
Seth Madore
Message 8 of 166
HughesTooling
I'm using an HPz620 Xeon E5-1620 workstation and an HP Envy i7 laptop both work well. One difference they are both running Win8.1 I stayed away from Win10, there seemed to be too many problems on the CAD forums.
Mark
Mark Hughes
Message 9 of 166
I've got similar spec on computer, and working on waaay less complicated stuff than you guys and mine crashes alot.  Over the last two days, my system has sent about 15 error reports to autodesk.
hope they do a little more testing before rolling out future updates.
Message 10 of 166
I'm having tons of crashes on stupid simple stuff.
My latest, I imported a DXF of a logo onto a surface.  The idea is to engrave it.
Just import it, scale it, give it the thumb and cheek artsy thing and go.
It would seem anytime I have the imported DXF sketch displayed while trying to CAM tool paths it gets really pissed off and hard freezes.
This is just the latest crash
My file revs are really rolling FAST lately
Message 11 of 166
justo_urbina12
I guess Windows 10 is the issue here as Mark has mentioned, mine crashes when I try to edit the lines of an svg file in the sketch environment.My specs are 5820k, 8gb of ram, radeon r9 370 4g, 2tb hard drive and Windows 10.
Message 12 of 166
HughesTooling
If anyone wants to upload an f3d file I'll try it on my system and see if the problem's in the file or down to the system.
Mark
Mark Hughes
Message 13 of 166
Tianq
Hi gearsoup,
Did you send the CER to Autodesk when the crash happens? If so, we can track the CER issues and see what causes the issues.
Dave
Dave (Qing) Tian
Message 14 of 166
LibertyMachine
Every time it crashed and I was given the opportunity, I submitted a crash report. I choose that phrasing to my answer because I'm not always given the option. Sometimes it crashes with the option, other times it's simply frozen solid requiring me to kill the application. A little side confession; my CER's, while they did explain what I was doing at the time of crash, did end up developing a bit of snarky attitude as the crashes became more common.
It's happened on my Windows 10 PC in the shop, my Windows 7 PC in the house (i5, 16gb ram, 1gb nvidia) and of course this dinosaur laptop I'm on, but I don't want to include that machine in the discussion, as I REALLY SHOULD NOT be running on this machine. (64mb graphics, 512 mg ram, i3)
Seth Madore
Message 15 of 166
justo_urbina12
Here is mine.
Message 16 of 166
gerry_kmack
FWIW, frequent crashes in F360 have been my ongoing experience for quite some time. As with several other posters, I usually post some info about the crash when asked to do so, but in many cases, F360 just freezes, and I have to force quit to end it. One commonly occurring instance is just trying to save a new version on a medium sized project. I tried to do that last night, left it running overnight, but this morning the "wait" wheel was still spinning. I must say that it doesn't appear that anyone ever reads those crash reports, as I have repeatedly written about the same symptoms (over several months) and never seen any acknowledgment that there was a problem. Also, FWIW, I am working on a Mac (high end iMac new last Fall), where most other folks seem to be working in Windows. Also somewhat contrary to other reports in this thread, the number of crashes (crashes/day) does seem to be down a bit since the last update, but there are way too many to call F360 a stable product.
Message 17 of 166
HughesTooling
@justo_urbina12 wrote:
Here is mine.
Clipboard01.pngI'd written the bit below before trying your model, I've left it in the message because I still think Fusion's not really suited to this type of work. I don't have time at the moment to select all the curves in your file but I got this far in a minute or 2 without any problems. The files attached at this point, I'll see if I can do the rest later.
To be brutally honest I'd say Fusion is the wrong program for something like that. For 3d work it produces the best toolpaths I've seen, but for 2d it rather limited. From what I've read HSM was developed for 3d mould and die work and the 2d was more a demo for HSMExpress. The 2d capabilities are good enough for adding pockets to a mould you might not want to model in 3d but it doesn't really have the tools to work with all those curves.
Mark
Mark Hughes
Message 18 of 166
Tianq
Did you write down your email address into the CER? It is needed to retrieve the related reports.
Dave
Dave (Qing) Tian
Message 19 of 166
LibertyMachine
I did not specifically type out my email address, no. I was under the impression that the CER was tied to my account
My email address is
libertymachineshop
at
gmail
dot com
Seth Madore
Message 20 of 166
AmishSolanki
I've also noticed the issues in the last few days. Non stop crashing. I counted about 5-6 times on Friday alone. Again doing simple stuff like editing a drill cycle. Right click, select edit, then crash. Today it's happened twice again. The next issue, is I go to open Fusion again, and it hangs on the logo screen. I need to force close it, and try opening again.
I log everytime it crashes, because I know it helps developers. The recent one is: CER_134768178
SS CADCAM - www.sscadcam.com
@sscadcam
