Spiral TPath: Any way to get it to generate spirals with concentric circles?
FrodoLoggins
Advisor Advisor
FrodoLoggins
I have Spirals with Circles checked but I can only get spirals:
Screenshot 2023-10-03 at 1.02.11 PM.pngScreenshot 2023-10-03 at 1.02.20 PM.png
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
programming2C78B
In the 4th tab is Concentric circles. Check your tolerances to make it complete at the edge. Can also do a 2D contour before the spiral that goes along that outside edge.
Flat will also make the spiral shape you are after.
Please click "Accept Solution" if what I wrote solved your issue!
seth.madore
That's because your Outer Limit on your 4th tab is set too large. You want to set it equal to your outer radius that you want to machine, minus your stepover. In this case, the value should be 11.325". Result:
Seth Madore
