Slotting
Slotting
britovsekmatic128
Slotting
britovsekmatic128
i would like to know if it is possible to machine the slot corners completely that they match the 3D model without using  small tools(Less than 4mm (0.15748 inches)).
Accepted solutions (3)
seth.madore
3D Contour, set your Heights properly:
ā€ƒ
Seth Madore
britovsekmatic128
Thanks @seth.madore
only problem is the part extends in Y+ direction and the endmill would be cutting into the part when it is going around the corner. Is there a way to constrict the tool path only at one end?
seth.madore
Yep!
Seth Madore
britovsekmatic128
Thanks a lot @seth.madore !
Follow up question if i may?
Is There a way to make the surface extend follow the 3D model in a parametric way?
For example if i have a workpiece a diffrent lenght i only presspull in the Y+ direction and the surface extend will follow the model whatever the lenght?
seth.madore
Sorry, only one question per user per day.....
(that was a joke!)
So, something like this?
Seth Madore
britovsekmatic128
lol @seth.madore
yes exactly what i mean! Thanks a lot i've owe you one!
