Sinumerik 808D Advanced Post generates G53 G0
apsTWRDF
Message 1 of 9
apsTWRDF
I know its a common topic but I dont just want to download a modified post processor. I would like to know where in the post processor this line is created and how to change it.
Problem is the standard Siemens 808D post processor creates a line with G53 G0 which doesnt seem to work with the 808D Advanced in my machine, because its not homing on the G53 machine coordinates. They are just somewhere, where the manufacturer placed that point and trying to move there would most likely crash it or at least the machine cant reach it.
If I remove the line all is fine, but then get an error that feedrate isnt defined.
So maybe someone can help me out showing what to modify in the standard 808D post to remove that g53 G0 and replace it by a simple F1000 for example.
Would really appreciate some help on that!
Jochen
Replies (8)
Message 2 of 9
g-andresen
a better place for you is the Manufacture Forum
günther
Message 3 of 9
Hallo
das gleiche Problem habe ich auch. Wie kann man G53 Ausgabe deaktivieren?
"I also have the same problem. How to disable G53 output? "
Translated by DeepL
Message 4 of 9
apsTWRDF
einfach in Fusion unter „Fertigen“ den Postprozessor aufrufen. Im Fenster dann beid den Postprozessor Eigenschaften unter „Safe Retracts“ statt G53 -> Clearance Height auswählen.
"Simply call up the postprocessor in Fusion under "Finished". In the window, select Clearance Height instead of G53 under "Safe Retracts" in the postprocessor properties."
Translated by DeepL
Message 5 of 9
apsTWRDF
Achja, danach hatte ich noch das Problem, dass er bei mehrfach Bohrungen in einem Zyklus nur eine Bohrung gemacht hat.
Falls das bei Dir auch der Fall ist, sag kurz bescheid, dann suche ich Dir das auch noch raus.
Gruß
Jochen
Message 6 of 9
Habe so die ganze Zeit stehen, aber die N Line mit "G0 A0" wird immer generiert!
Message 7 of 9
apsTWRDF
Bei Dir steht unter „Rotary table axis: Z“
Wenn Du keine 4. Achse hast ändere das mal auf „No rotary“ im Pull Down menu.
Message 8 of 9
Das ändert leider auch nichts. Es wird immer die N G0 A0 generiert.
Bei dir nicht?
Message 9 of 9
Habe den Fehler gefunden! Oben hatte ich die ganze Zeit die "Autodesk A Axis" Maschine stehen, sollte 3 Axis sein!
Aber danke für die Hilfe! Es wäre Super wenn ich über dem Postprozessor genau an der Stell wo "N30 G0 A0" war, eine N-Line generieren könnte mit dem M60 Befehl. ( N30 M60). Damit wird Minimalmengenschmierung bei meine Maschine aktiviert. Eine "Luftpustedüse".
L.G.
