Simulation not stopping on first collision
FrodoLoggins
Advisor Advisor
FrodoLoggins
https://youtu.be/k3OsIdnImKg
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
mattdlr89
This is most likely to do with accuracy settings. I've seen it as well.
The simulation checks for collisions at 33% accuracy and that's how it works out where collisions are in the bar at the bottom and when the tool turns red. If you run simulation at a higher accuracy like you are (66%) then it realises it isn't a collision and doesn't stop.
Not very helpful but that is what I believe is happening... Hopefully it'll get fixed one day.
engineguy
@FrodoLoggins
If it is a "Light" violation (Very thin Red Line) then it is usually missed if the Simulation is run at high speed, if it is a thicker Red area then it will stop (Mostly).
How does it go  "Kill your speed-not the Part"
