Simulation does not match program
lethal375
Message 1 of 8
lethal375
Fanuc 21iT control
Fanuc turning processor in Fusion 360
Tring to make a pulley and the simulation work fine
When I tried the program in the lathe it does not match the profile in simulation
Its like the v groove profile is shifted in the +Z direction
First tool T0404 does the facing and rough profile to diameter perfectly
Tool T0202 starts the profile by making a pass across diameter (light cut) then begins putting the fillet on leading edge. Nice fillet
Now it should start the first V groove, but it moves -Z not enough for first groove and then dives in (See pic)
I have made several checks on the tool calibration in lathe and its spot on.
When it dives in, I stop it and checked location in both X & Z, all good.
Can move over and verify the tool is still on Z0.0
I have tried the tool comp in tool set up but no luck
Replies (7)
Message 2 of 8
lethal375
Forgot to add file
Message 3 of 8
a.laasW8M6T
Hi
How are you touching the tool off in the machine?
You have the Compensation set to "tip center" in Fusion
are you touching the side of the tool on the tool setter and then adjusting the offset by half the tool width?
if not and you are touching on the side and setting that as z zero you should have the Compensation set to "Tip"
Message 4 of 8
lethal375
I have tried both ways
Each time I changed the machine offset accordingly
Have always used the left side with no problems till now, if that's the issue
I make several parts that use a straight 35 degree tool with comp on center and never had an issue
Message 5 of 8
seth.madore
The file that you shared doesn't have a Grooving tool applied, nor is there one in the document library (aside from the adjustable part-off tool). The VNMG (Neutral) tool that you are using is set to Tip Tangent, so I assume you're calculating where that tip is and adjusting your tool offset (in the machine) accordingly?
Seth Madore
Message 6 of 8
lethal375
I added the VNMG to the project just to try the simulation.
I know I have used parting tools like this before with no issues
The reason for using the parting tool this time is clearance to chuck jaws for the last v grove
So Fusion changes how it interoperates the tool based on category and geometry?
My Fagor control does not care about category only looks at the tool geometry and offset then moves accordingly.
Message 7 of 8
seth.madore
So your Fagor control adds an additional offset based on the tool geometry?
Seth Madore
Message 8 of 8
lethal375
The Fagor 8055 control has great conversational capabilities.
I wanted to use my big Clausing cnc because of the parts size/weight
The Fagor will allow any tool profile that will fit the part geometry.
You can draw the profile on the control screen and select a tool
If the selected tool geometry will cut all of the profile features, it works
It does not matter what category the tool is considered, grooving, parting, profiling, etc.
Got it done on the Clausing flat bed with the Fagor control
Had to take light cuts due to vibration
