Can anyone help with this, please. I have a XYZ Lathe with with mill/turn capabilities with a Siemens 828D control.
I am using the Siemens generic turning post, and with my limited capabilities have managed to make some tweeks (M code for coolant parts catcher etc). However, when posting out programs I have come up against a couple of issue, listed below:-
1.For drilling cycles, the feed rate is posting out in a figure of mm/min, but the the control is taking this as mm/rev. F150. is being taken as 150mm/rev, for me the feed rate should post out as say F0.2.
2. Again, in the drilling cycles, the canned cycle is containing a G18 rather than G17. I am having to go into the cycle, in the machine, and manually change this. This is causing the machine to move 5mm in the Y+ direction and not move in the Z- direction.
3.At the start of the programs a G18 is being posted there also.
I have checked the set up orientation, within Fusion and this is correct.
EDIT***** the drills I am using are in the turret and not in driven tool holders, as they are drilling on centre line******
Any help on this, would be greatly appreciated. Maybe I'm using the wrong Siemens post contained within the library, or maybe someone has a working 828D Mill/Turn post that they are willing to share.
Once again, thanks in advance.
