Siemens 840d Generic inspection post does ot create a results file with Probe WCS function
blaz.znidarsic
blaz.znidarsic
Trying to use probe WCS to make some simple measuements in Fusion but the generic post does not seem to want to write said results in a file. Without being confident in the ability of the post to make the measurements i want i'm also unsure about spending any credits. My control is Siemens Sinumerik 840d on a 5axis positional machine.
I've only changed the Z-height of the post so my machine doesn't crash into the table on every tool change. For some reason Z=0 is at table height.  Inspection_file.nc was previously .mpf (which is correct for 840d control) but i couldn't upload it to the forums. Ergo i changed it to .NC just for the upload.
Question is: Why does the machine make proper measurements i like but they're not written to a file and how do i correct that? If i have this functionality i'll be much more likely to buy a day of extensions now and then to supplement Measure WCS with more options but i'm not able to justify said expense for something i should be able to do without. Sinumerik control returns me a beautiful results screen on cycle end so apparently some "write" command is missing.
i've dabbled in posts a wee bit to make them suitable for our machines but i'm not confident in a major rehaul.
Machine is Spinner U5-1520 - Sinumerik 840d control, 5 axis with an additional stationary table. CNC code from the generic posts is good, i've had no problems with it so far and been using it for a while. I'm only bothered by this bit.
Tomek.G
Hello @blaz.znidarsic,
As CYCLE100 isn't a part of basic package of sinumeric measuring cycles, we decided to use display of measurement result screen instead of logging in a file in our Generic post.
If you have CYCLE100/CYCLE101 available you can use it to activate/deactivate logging into a file.
Tomek.G
Sr. Technical Consultant
