Should total tolerance (tolerance+smoothing) be set to the machine's precision ?
hey everyone ... a quick general question about using the tolerance and smoothing srttings. I understand the concepts and have been using tolerance and smoothing quite a bit but am wondering about the tolerance settings.
So i'm working on a machine that per manufacturers specs has a precision of 0,05mm. Since the maximum deviation is calculated as tolerance + smoothing tolerance .. does that mean i should always aim for a total tolerance in Fusion of 0,05mm as well .. so tolerance of 0,025mm and smoothing tolerance of 0,025mm ? or are the tolerance settings and machine precision not really related ? if they are not directly related does it make sense to choose a tolerance which is smaller that the machines precision when optimising gcode for a specific operation ?
AppleSilicon Macos 26.4
GENERAL DISCLAIMER: if there isn't a file attached to my posts then there is a reason for it. Whenever needed or whenever i can i will attach a file for troubleshooting. If no file is attached i will always try to explain as clearly as possible and if needed or helpfull provide illustrative screenshots. When i have an issue that can only be helped by attaching a file which i cannot share publicly i won't ask about it here.
