ShopBot 5-axis CNC error: "Parameter value below range for VS..."
When posting toolpaths created in Fusion 360 using the Autodesk post processor for ShopBot (https://cam.autodesk.com/posts/download.php?name=shopbot) I constantly get the above error. I have modified the line in the post processor to say ‘fiveAxis: true’, but have not edited anything else.
When using 3-axis or 3+2 functionality, I can post .sbp files without issue, as these files only contain "MS" commands and not "VS".
When attempting to use ANY 5-axis functionality, such as Multi-Axis Tilting, the post processor writes lines including 'VS' commands, which generally have two numerical values, and one of those values is always 0. However, the usable tolerance value of VS needs to be between .05 and 12 in order to function. No matter what variables I adjust, I cannot find a usable sweet spot and will always get an error message that the parameter value is either ABOVE or BELOW the range for VS.
I understand that VS denotes degrees-per-minute (dpm) rotational speed, but can't seem to find the variable within Fusion 360 that correctly outputs a useful value.
The only viable "workaround" I have found is to edit the posted .sbp file manually (using find and replace) to change the VS value from 0, to a value within the tolerance range. This is obviously not a sustainable practice, as there can be hundreds of thousands of lines of code in a post file, and can take hours to do. Additionally, when I do this, the machine accepts the values, but moves in a very jittery and stuttering fashion, which is also unacceptable.
I have been back and forth with ShopBot tech support, but they have been occasionally unresponsive and not helpful, and have told me to consult with Autodesk tech support, as they don't have a fix for this. (?!)
Is there a modification for the post processor or a variable within Fusion 360 that outputs usable VS values in the .sbp file so that I can utilize 5-axis functionality in my ShopBot Router?
