Setups Referencing Previous setups
JerryLJr
JerryLJr
I am cutting side one and want to make that a stock model for cutting side two. Is there an easy way to do this?
LibertyMachine
There aren't any EASY ways, if that's what your asking. If your model isn't too elaborate, I often just duplicate it and add material to it to represent most of what OP2 would be seeing. You cna do this by selecting the Model and simply CTRL+C, CTRL+V.
If your model is quite extensive, you can run the simulation through the first Setup, right click on the screen and "Save Stock". You would need to re-import it, and it's likely going to come in at 25.4 times the size
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
LibertyMachine
And here's a quick screencast showing the how's and why's
Seth Madore
