Setup Sheet Failed
Setup Sheet Failed
kevinFZF99
Setup Sheet Failed
kevinFZF99
The following error occurs when trying to create a setup sheet for one particular part.
Error: Publish setup sheet failed: setup sheet file not created for file. Post-process the NC Program(s) with the Setup Sheet (JSON) cps post to find the root cause.
I tried posting with the JSON post but to be honest it is completely foreign to me and I don't see any direct references to what is wrong.
Does anyone else use the Fusion Manufacturing setup sheets and have any guidance on how to trouble shoot errors with manufacturing setup sheet creation?
Thank you,
Kevin
gunner5607
I'm getting the same error
Publish setup sheet failed: setup sheet file not created for file 3040. Post-process the NC Program(s) with the Setup Sheet (JSON) cps post to find the root cause.
I can see older setup sheets but my latest 2 designs give the same error.
If I click on Setup and then Setup Sheet I get this failure message
Information: Configuration: Setup Sheet (HTML)
Information: Vendor: Autodesk
Information: Posting intermediate data to 'C:\Users\Darrin\Documents\Fusion Setup Sheets\Glock Standard 507K CUT v6.html'
Error: Failed to post process. See below for details.
Code page changed to '1252  (ANSI - Latin I)'
Start time: Thursday, July 6, 2023 3:33:08 PM
Code page changed to '65001 (UTF-8)'
Post processor engine: 4.5971.0
Configuration path: C:\Users\Darrin\AppData\Local\Autodesk\Autodesk Fusion 360\CAM\cache\posts\setup-sheet.cps
Include paths: C:\Users\Darrin\AppData\Local\Autodesk\Autodesk Fusion 360\CAM\cache\posts
Configuration modification date: Monday, November 21, 2022 12:13:58 PM
Output path: C:\Users\Darrin\Documents\Fusion Setup Sheets\Glock Standard 507K CUT v6.html
Checksum of intermediate NC data: 3a67af7229af89c2cb6d86af3e864993
Checksum of configuration: 0d1af919dae3627f8b2809d847cb4453
Legal: Copyright (C) 2012-2021 by Autodesk, Inc.
Generated by: Fusion 360 CAM 2.0.16490
Error: Machine configuration is not compatible with operation.
Error in operation: 'Spot Drill'
Failed while processing onSection() for record 2798.
Error:
Error: Failed to invoke 'onSection' in the post configuration.
Error: Failed to execute configuration.
Stop time: Thursday, July 6, 2023 3:33:09 PM
Post processing failed.
