Setup adding unwanted material to Z axis
jmorphet
jmorphet
Trying to do a setup for a pair of soft jaws. The jaws are already the correct size so I don't need setup to add any additional material to the stock size. I set the stock offset to "No additional stock". The jaws are 2 x 2 x 6. Setup as a pair with a 1" gap, the stock dimension should be 2 x 5 x 6. Fusion 360 is adding .0625 to the Z Axis. I am attaching the file to this post. Can anyone see why this is happening?
jmorphet
I figured out my own answer. I had the part I intend to make in the drawing. The part was hidden, but setup still saw it when it was determining the Z axis stock thickness. After removing the the part from the model, the stock thickness was correct.
