Sequence numbers only at tool change.
dluebkeETCQE
dluebkeETCQE
I would like to have my post output sequence numbers only at the tool change. The current configuration only outputs at every line or not at all. How can I change it to allow every line, only at tool change, & disabled? I've attached the cps file. Thank you.
boopathi.sivakumar
Hi @dluebkeETCQE
The current Fanuc post does have this option to output sequence number on tool change
I think your post is very similar to the latest one you can compare and make the changes necessary to your post.
let me know if you have any issues
Boopathi Sivakumar
Senior Technology Consultant
