Scallop Toolpath issue
There is a surface imperfection on our part that is not shown in toolpath preview or simulation. The "lines" will have to be sanded out as they are able to be felt with a finger nail. I've attached pictures showing the defect, as well as provided machining details below (for reference).
Please note: The set up is rigid, so we should exclude surface variations due to machine, tooling, or operator error.
Has this issue been noticed before with this particular toolpath?
As the preview appears to be without issue, I can't imagine there is a setting/machining attribute that would be able to resolve this.
Any feedback would be greatly appreciated.
Material: 6061-T6 aluminum
Cutter: 2 flute carbide ball mill (Harvey), .125'' length of cut, .500'' overall length
RPM: 36,000
Feed rate (IPM): 75 I.P.M.
"One-way" direction (climb cutting)
Stepover: .001''
Tolerance: .0003''
No smoothing (smoothing controlled on the machine with Dynamics and Contour Smoothing commands)
Tool Holder: HSK E-25
CNC Machine: Datron M10 Pro
Thank you.
Best Regards,
Dave Blandino
