Scallop Toolpath Help
bpetersen9BTH4
bpetersen9BTH4
Hello Everyone,
I am having an issue with using the Scallop toolpath, I searched around the forums and I couldn't quite find an answer to my problem.
It seems like there should be an easy fix. Perhaps something simple I'm missing.
All I would like to do is switch the direction of the scallop toolpath to machine from inside to the outside
I have these parts with a multi axis chamfer ring type area and I would like it to cut from the inside bottom to the outside top.
Right now I got it to produce a nice toolpath and I just need to switch the direction. Selecting the "Link from inside to outside" option doesn't seem to change anything.
The reason why I want to cut from the inside out is because I typically get better finishes that way and this is a consumer product.
I have attached the file to this post. Hopefully this is a simple fix
seth.madore
Actually, if you're interested in a better toolpath for this feature, I'd suggest turning on the Blend toolpath in the Preferences > Preview Features:
Resulting Toolpath:
 The order in which you select your Drive Curves will influence the inside/out approach
Seth Madore
bpetersen9BTH4
Thanks for your reply @seth.madore ,
What you have in your second photo is exactly what I am trying to achieve,
I turned on the Blend toolpath and Im going to try it out now,
are you able to attach the file you that you used in the photos?
seth.madore
Here you go 🙂
Seth Madore
bpetersen9BTH4
Thanks Seth!
