Save default values- not including check box selections ie keep tool down.
ELAFING
ELAFING
There was a right click selection for "make all default" this would take all values on the selected tab future defaults. Now there is "save as user default". The problem is this new save does not save any check box select/deselect options. Can someone point me in the right direction here?
Thank you.
seth.madore
When you create a toolpath, you can right click on it in the Browser and select "Save Parameters as Defaults", that should do the trick
Seth Madore
ELAFING
Thank you so much.
