Same tool entry and exit in ramping 2d contour
mgolor
Observer Observer
mgolor
Observer
Observer
I've just started learning Fusion 360 CAM and I faced a simple problem. When I choose to mill a contour with ramping, entry of the tool is in different place than exit. I've chosen the entry point but it generated toolpath with exit point in that place and entry is in different one. Milling starts at model Z=0. What is the problem ?problem1.png
seth.madore
When Ramping into a part, it's not so easy to define the exit point. If you're entering into open area (as opposed to plunging into stock), consider using the Multiple Step Down option instead of Ramp
Seth Madore
